1 - 7 of 7 Posts
Hi all - I'm hopeful that the community can help me diagnose a rattling noise that I've been noticing. It's a 2014 Cruze LT with 235k miles. The engine idle is reasonably smooth considering the car's age. The rattle noise really only happens when I'm accelerating and typically around 1,500 RPM. When I have the car parked and rev the engine, there's a faint rattle, but it's nothing compared to the sound when driving. From what I can tell, the noise is coming from the passenger side of the engine compartment. I've included a short video below so that y'all can hear it. Any guidance and ideas are greatly appreciated. Thank you all.
Check the mounting bolts for the AC compressor bracket, might be missing a bolt.
Well, much to my surprise - this was the exact culprit. The top bolt was missing from the a/c compressor mounting bracket. I headed over to Home Depot to find a replacement and viola - no more rattle! It took me a bit of trial and error, but I'm fairly certain it was a M8-1.25 bolt that did the trick. I'm leaving a link in the event that others are seeking a replacement. Thanks a lot for the suggestion. I'm amazed that a $3 bolt solved what I thought would be a time consuming repair.
Been there, rattled that. That is why I suggested it and then only to find out that the issue is common on this engine. I guess they only had the torque wrench turned up to 3 instead of 10 in that foreign factory
2016 Limited LT 1.4T 6AT
I am having weird noises as well but only once I hit around 38-40mph. I'm pretty sure it is the splashguard in the front drivers side wheel-well. It's a little loose and hangs a little bit below side skirt so at high enough speeds it starts flapping around.
1 - 7 of 7 Posts
