Car is super sluggish & gives on of the dpf messages when started but says to “keep driving”
Since your saying the car is saying to keep driving I would attempt to clear the codes, for sure the 003a and p24a5.Car is super sluggish & gives on of the dpf messages when started but says to “keep driving”
Keep driving means that it is trying to regen. If it says that, well keep driving. I believe it is 40+ mph for X amount of time. Should regen and clear the dpf. Probably a lot of city miles.Car is super sluggish & gives on of the dpf messages when started but says to “keep driving”
This is the EGR bypass at 100k. The girls dirtyP2463: Powertrain control module
Possible causes for this engine code include:
Excessive soot accumulation due to insufficient DPF regeneration
Bad DPF pressure sensor
Insufficient diesel exhaust fluid Incorrect diesel exhaust fluid
Shorted or open wiring to the DPF injection system or exhaust pressure sensor
Defective PCM or a PCM programming error
Faulty exhaust pressure sensor
-- I'd start by looking at harnesses that are located near hot exhaust components and sharp exhaust shields.
P003A: Turbo boost control position exceeded learning limit
Possible causes include:
Turbocharger or supercharger vane adjustment
Faulty turbocharger or supercharger
-- Check for damaged components and look for broken, bent, pushed out, or corroded connector's pins.
P24A5: Exhaust Gas Recirculation Cooler Bypass Control Circuit /Open
Defective EGR cooler bypass valve
Clogged or damaged EGR cooler
Temperature switch malfunction
Excessive carbon buildup
Faulty or damaged wiring Corroded, damaged or loose connector
Defective ECM
-- I'd start looking around the EGR first
oh yeah, I'd replace that. I believe it's a fairly inexpensive part too (around 60$-65$)
It’s not going back in 😉oh yeah, I'd replace that. I believe it's a fairly inexpensive part too (around 60$-65$)
Let me know how it works for ya!It’s not going back in 😉
2nd time doing this, she will breathe beautifullyLet me know how it works for ya!
