1 - 3 of 3 Posts
welcome
i have this code p2108 by obd2 scanner
how can i fix that
my car : chevy cruze 2010 1.8
This is what I found:
P2108 CHEVROLET - Throttle Actuator Control Module Performance
P2108 CHEVROLET Possible Causes
  • Faulty Throttle Actuator Control (TAC) module
  • Throttle Actuator Control (TAC) module harness is open or shorted
  • Throttle Actuator Control (TAC) module circuit poor electrical connection (loose or broken wires)
What does this mean?
How do I fix code P2108 CHEVROLET
  • Check the "Possible Causes" listed above. Visually inspect the related wiring harness and connectors. Check for damaged components and look for broken, bent, pushed out, or corroded connector's pins.
HTH.
Doug
welcome
how can i fix that. If you want to buy obd2 scanner, visit AutoGuysLand to review it before getting one. my car : chevy cruze 2010 1.8
It is possible issue with your faulty throttle body or position sensor. Try to look at this and replace if necessary. Good luck
1 - 3 of 3 Posts
