1 - 4 of 4 Posts
Hey ,folks Im a new member looking for help
I just replaced a long block in a 2014 , every thing that needs to be there is present, compression, spark,55lbs. fuel pressure. Yet it wont start. I have changed hundreds of motors in my life, and have never run into this. also in all of th cranking of the engine there is no oil in the oil filter housing. 1.4 turbo.please give me any tips you might have.
2013 Cruze LT
Timing correct? Does it sputter or try to start at all?
Same issue for me.
Same issue for me.
Welcome Aboard!(y)
Start a thread here and explain the issue and what you have done so far. Make sure the title helps explain your issue.
1 - 4 of 4 Posts
