I need some help, the top of the strut is stripped out. When I pulled cover off of the strut, I found the hex head filled with rust, I used a a wire wheel to clean it out, but now I can't remove the strut. I don't want to cut it out, it is a Bilstein coil-over and these things are not individually sold.
Has anyone successfully repaired a stripped hex head.
So far I have tried to epoxy a bolt into the hex head and have tried using a reverse threaded extractor.
