Hello,
I've looked through the forum to see if anything is out there could help me but I couldn't come to a conclusion. I've just purchased MSR Style 144 Concaved Wheels with a Size of 18x8,5x114.3 BP and 35 Offset. I know I will need an adapter, but I'm not sure which adapter I will need. This will be going on a 2015 Chevy Cruze LT. The Standard Wheel size is 6.5Jx16 ET39. So, if my wheels that i'm purchasing have a 35 offset then that makes the current offset a -4, correct? So if I have to add an adapter, should I go with a 20mm(smallest I saw) to make it +16 or a 25mm to make it a +19mm or should I go larger? Im basically wondering what would be a proper sized thickness for the adapter and my wheels.
Thanks in advance.
114.3 wheel is going to be your first challenge.
8.5 inch wheel with a +35 offset will be tight fit with no adapter. Adding an adapter will only make it tighter. Good luck.
