in this order
codes: p0238
p2227
p0122
p0223
helping neighbor, in january she got the throttle body replaced at the dealer.
Last week she said when getting on to the freeway she floored it and she heard a "woosh" and the car didnt have power after that. when she left work it had power again. then when getting onto the freeway she heard a "woosh" again and the car didnt have power the the CEL turned on.
i connected my ELM and ran torque and pulled the above codes. i cleared the codes and started it and then checked for codes. it immediately had P0122 & P0223 in pending. took it for a drive and it had power until the on ramp. then "woosh" then no power, boost would not go above 8psi according to torque. CEL turned on and i pulled the 4 codes listed above. i swapped her MAPs with mine, cleared the codes, started it up and it had P0122 & P0223 in pending. took it for the same drive, again "woosh" no power and again boost would not go above 8psi. Then CEL again. pulled the same 4 codes. brought it back and pressure tested, no leaks at 25psi. valve cover good, intake still has the nipple.
could the throttle body go out that quick?
what the heck is going on with the MAP codes??
can you make me look like the hero?
codes: p0238
p2227
p0122
p0223
