2011 Cruze 1.4t
So I got the turbo low output service code. Also engine is low on power. Took it to a chev dealer and they say they found a significant vacuum leak that may be the cause. They can't diagnosis the turbo till the vacuum leak is repaired. They say the leak is from the front cover. 6 hours work. The pan needs to be dropped and rocker cover off to do this. Also about $380 in parts.
I thought the front cover would be under pressure from the base and not vacuum..They say the cover is intagreated with the EGR and it needs a new gasket to solve the vacuum leak.
Does any of this make sense?
If I need a turbo after this the bill will be catastrophic.
