1 - 7 of 7 Posts
Hi.. i've just had a new radio in my car.. after the installation, the parking assist and seat belt warning doesn't work.. the turn signal doesn't make the clicking sound anymore either.. do any of you guys have this problem? Is there a fix? Thanks
I like the pac-audio RP5-GM41. It sounds like someone just hardwired it. The BCM communicates through the radio so you need a module to interface so you dont lose the things you are describing.
Discussion Starter #5
I have the Scosche GM5202AB.. is there anyway i can use the stock usb and aux to work with my aftermarket radio? i have the pioneer avh-x4700bs
Did you plug the little black speaker that came with it (should have green and yellow wires attached) in to the GM27SR?
If so where did you mount it
1 - 7 of 7 Posts
