1 - 1 of 1 Posts
I put this in the wrong sub forum... but you can blame that on the page's super slow loading times! the page shifted last second when I was clicking the link=p
I just thought of something and I want to know if any of you think this is possible.
My 2011 A/T jerks into 4th gear sometimes really bad as if the clutch timing is off. It always happens after I stop the car/shut off engine for a few minutes and then get back on the road. It never happens after an over night park.
My question is:
I know transmissions have all sorts of synch timing gears and all that.
Is it possible that there is a soft reset and a hard reset for these synchs? I'm wonder if my soft reset is messed up? and then after the car is sitting for a long time it hard resets.
Is this at all possible? I know there is some sort of software in the car that controls the transmission, maybe it needs to be reprogrammed.
*edit i just thought of something that I will test, I go through phases where I use the manumatic mode a lot, and due to it being designed stupid I use the trick where I start off in 2nd gear usually. I wonder if doing this is throwing something off after coming to a stop and shutting off the engine is leaving something out of whack. Then when I get back on the road I get that nasty shift and then it synchs back up after that first bad shift.
I'm going to test it over the next few days.
1 - 1 of 1 Posts
