I've got my original plugs gapped to .038" with my resistors bypassed and so far everything is good. If I go with the coppers I'll toss them in at that same wide gap and report how she goes.
Cool - let us know how they work out for you.Ok I went to the parts store tonight and picked up the plugs. They were $2.59/plug from Advance Auto Parts. Just out of curiosity I checked the gaps on them and they are all gapped at 0.35 in the box. I'm going to knock it down to 0.30 before I install them in my Cruze. I am curious to see how this works out also.
That's great to hear! Nice to see some consistency!...they are all gapped at 0.35 in the box.
I'm actually suprised those who are tuned aren't running 1 step colder plugs... I ran colder coppers in my cobalt, supercharged corolla and built n/a focus.. They would last about 10 k but that meant swapping them once a year at the time.Searching around for plug info, I found this Amazon listing for an iridium BKR8EIX, basically an iridium tip version of the colder 8 heat range BKR8E-11 plug I referenced above. Check out the first review:
NGK BKR8EIX Iridium IX Spark Plug : Amazon.com : Automotive
That guy had NGK platinum 7's in his naturally aspirated S2000 from the factory, and the only noticeable improvement going to the iridium 8 was no more timing pull at lower RPM. His car is supercharged, and a quick Google search shows that most S2000 superchargers are centrifugal superchargers which make little to no boost at low RPM.
Unless there's some tuning issue where they had to add timing at low RPM when tuning for the blower, it looks to me like even a stock S2000 may have benefitted from this colder plug. This, of course, is all based on reading between the lines of a short Amazon review... not much credibility. But, in an optimistic sense it would look good for trying the colder plug in our boosted 1.4's.
All else remaining equal, a colder plug may foul easier. Still might be worth a try...
Yes - I did the same with my turbocharged, tuned Volvo to alleviate a stumble @ high RPM when the boost hit full-force.I'm actually suprised those who are tuned aren't running 1 step colder plugs... I ran colder coppers in my cobalt, supercharged corolla and built n/a focus.. They would last about 10 k but that meant swapping them once a year at the time.
Im going to try some copper ones out which would y'all recommend me to try.I'm actually suprised those who are tuned aren't running 1 step colder plugs... I ran colder coppers in my cobalt, supercharged corolla and built n/a focus.. They would last about 10 k but that meant swapping them once a year at the time.
If a colder "8" heat range IS worth something on this motor, this plug is available with a starting gap of .044":
[NGK-BKR8E-11] - - It's Free! : NGK Spark Plugs Store!, NGK Spark Plugs We Sale, Spark Plug For Racing car, Automobile, Motorcycles, ATVS, Scooters, Marine Engine, Agricultural Equipment
Well I called my local parts place and they stock the BKR7E for $2.78/ea, but that's too cheap.Blue Angel said:All else remaining equal, a colder plug may foul easier. Still might be worth a try...
The Cruze originally came with NGK's heat range "6" (a hotter plug). They moved it up to the 7 in 2012, according to a link Blue Angel posted earlier.Im going to try some copper ones out which would y'all recommend me to try.
Sent From An Antique,
My Original Droid.
I remember ordering light bulbs for a non-Honda vehicle through their dealers too for about 1/3 the cost.Blue Angel said:So I'm going to pick up a set of Honda dirt bike plugs for my Cruze turbo next week, gap them to some crazy spec that will never work, drive so easy they will never get up to proper temperature, and try to set GOLD Hypercruzer status before they foul up. That sounds like just the right amount of dumb. Wish me luck.
Will do. This will basically be an experiment to see if low RPM torque is improved at all, and whether the colder plug fouls up. If my grandma-driving habits can't get this plug to foul I doubt anyone else would have a problem.Run em up to redline before you fill up and see how they do.
I think those arent for a old ford pick up truck. That plug is real popular in dodge dakotas. Iirc they are a heat 6 or 7. My build date is 9/11 but its considered a 2012 so i wonder what heat range i have.They sent me Autolite 3923 are those correct sorry I'm mlnot at a pc.
My Original Droid.
10/11 here with the 7's.I think those arent for a old ford pick up truck. That plug is real popular in dodge dakotas. Iirc they are a heat 6 or 7. My build date is 9/11 but its considered a 2012 so i wonder what heat range i have.
