When I switch on the high beams-nothing glows-no highs, lows, or fogs. On low beam, lows & fogs work. There is no power under both high beam fuses #37 & #38 in checking them, but both are good. My Question is where is the high beam relay in the engine compartment fuse block-what number is it?
Good question. I'll have to check the manual. Its certainly not showing up in the underhood listing nor the owner's manual. I hope it's not one of those relays that are part of the fuseblock itself and not changeable.
Likely BCM controlled.....no relay......near as I can figure.
From what I remember of the schematics, the high beams and fog lights are controlled by a relay driven by the BCM.
The low beam and all the low power stuff (parking, running, turn signal, brake, etc) is all driven directly off the BCM.
Bad news. The high-beam is one of 5 PCB relays that are part of the underhood fuseblock and considered non-serviceable. (Not a plug-in relay.) So it appears that you'd have to replace the whole fuseblock. At least if you want to do it the GM way. The GM Direct price is $150.
I haven't looked at it, but I'd suspect if you knew how to change parts on a PC Board, it probably wouldn't be too hard to replace the relay. You might get lucky and find a cracked solder joint that just needs to be reheated.
The fuses are after the relay. If the relay never closes, they'll never have power. So that's pointing to a problem in the relay or a connection in the fuseblock. (Or maybe the BCM/wiring harness.)
Bad news. The high-beam is one of 5 PCB relays that are part of the underhood fuseblock and considered non-serviceable. (Not a plug-in relay.) So it appears that you'd have to replace the whole fuseblock. At least if you want to do it the GM way. The GM Direct price is $150. "
Hi,
I’m facing a problem that seems to be connected to this issue with my cruze 2011.
My high beam does not stay on.
When I pull up the light handle the high beams turns on and turn off when I leave the handle.
When I pull it down, most of the time the high beam does not turn on. There are some rare times when it will turn and stay on.
I thought the handle is the cause of this, so I replaced it but it did not change a thing.
So probably the cause is in some relay.
Where does these “5 PCB relays that are part of the underhood fuseblock” are located?
Is there a schematic of these PCB so I will know which relay I should replace?
