Are you sure you are not seeing a difference between the DRL and the normal headlight output. If you are sure (or the highbeam indicator is on, on the DIC), It is probably an issue with the stalk switch.
When I switch on the high beams-nothing glows-no highs, lows, or fogs. On low beam, lows & fogs work. There is no power under both high beam fuses #37 & #38 in checking them, but both are good. My Question is where is the high beam relay in the engine compartment fuse block-what number is it?
