2014 Chevy Cruze
Eye Human body Fluid Amber Automotive tire
Hey, so there seems to me too much oil on cylinder heads. It's to the point where it's starting to drench the spark plugs. Any recommendations?? Have a picture if text doesn't make sense
The good news is the oil in the spark plug well is from a bad valve cover gasket. This is an easy fix, just replace the valve cover.
I'd assume the oil on the alternator is from the crank shaft seal. The crank shaft seal usually lasts forever unless the PCV system fails or the motor oil isn't changed.
2014 Chevy Cruze
Oh okay, thank you bro. I've replaced a PCV hose thinking nothing is going to happen to the crank seal. I assume that was wrong lmao. Would all of that as well clear up the engine knock?
