1 - 19 of 19 Posts
2012 LTZ 45k miles on 3rd water pump.
Another water pump about to fail? Sprayed belt with water made no difference, not overheating, coolant temps normal, engine bay has always smelled of coolant. No leaks visible.
I have, long before the whine began... just don't want her to be stranded, anyone had this whine prior to failure?
You only had audible noise and no leak from the weep hole? It's still functioning correctly.
A whine or squeal is often the first sign of a water pump starting to fail.
Whatever shop keeps throwing water pumps at this car REALLY needs to look into the tension or tensioner on the serpentine belt.
The previous 2 pumps were replaced prior to our ownership, but i'll mention it to the dealer... this thing was supposed to be a cheap fuel sipper, it's becoming annoying already.
Discussion Starter · #12 ·
it's 20f here and noise not evident nor is the smell in the engine bay, I guess i'll bring it in when it gets warmer and reoccurs
She drove it in traffic an extended amount of time today, smell and whine were back as she pulled into the driveway. Coolant Is dripping down the block so looks like time for water pump #4. Unbelievable.
Discussion Starter · #15 ·
Brought It in today was given a 2014 lt its much quicker in acceleration for some reason, what else is wrong with our 12 :/
Discussion Starter · #17 ·
Was 2014 pcm updated?
Mine is a diesel so I'm not sure. There were a lot of problems fixed and issues eliminated for the 2014 so I wouldn't be surprised.
Sent from the sexy electrician
Discussion Starter · #19 ·
shows about 11psi under full boost, slow, no codes, still smell coolant in the engine bay after it reachs op temp... cool car.
1 - 19 of 19 Posts
