First thing I would check is the connectors. The connector going to the coil pack is a known issue. I would also inspect and clean all 3 connectors on the ECM.
What are the fuel trims during the misfire condition?Hey all. I am a 2016 awd trax owner, yes I know I'm in the wrong forum but we all share the same engine..
Just wondering if anyone has experienced a high rpm misfire in their 1.4L only when WOT.. the car otherwise runs great. The misfire is heavy on cylinder 4.
Background on the car:
Zzp v3 ported, zzp diamond forged pistons, 42 lbs injectors, catless front pipe, ported intake, zzp sonic intercooler kit and zzp sonic air intake and tuned by zzp.
I've swapped injectors. New coil pack. New spark plugs gapped to .020" and misfire still takes place on cylinder 4.
Curious if anyone has run into this before? I suspect something valve train related but before I disassemble, want to see if anyone has experienced this before.
Thanks!
What's the #4 injector duty cycle and Spark plug look like?from my hp tuners scan, at 5900 RPM my misfire counter is showing 30 misfires on cylinder 4, fuel trim is showing short term 0% long term 3.9%
Would you get more complete burn with a bigger gap?New spark plugs gapped to .020"
thanks for your input, I am planning on buying valve springs and upgraded cam. I am also changing all lifters while im there.It sounds like you are running into valve float, esp given the visible cam damage
They do sell upgraded valve springs for these motors, and it is only usually an issue with a high-flow turbo and high RPM, both conditions you meet.
BNR Valve Springs 1.4T Cruze/Sonic-BNR-LUV-LUJ-VSPRING
store.badnewsracing.net
