So I placed a Hitch on the Cruze over the weekend for carrying bikes, and potentially a flat cargo carrier. The intent is to get a small portable grill out of the trunk when tailgating and roadtriping. Less than 50 lbs in the basket.
Does anyone have a hitch mounted cargo carrier that works well with the cruze?
I picked up the aluminum version of the basket from Harbor Freight, along with the 1 1/2x 2" adapter, and the basket sits too close to the ground. Also the tongue of this basket is really long. New mounting holes will have to be drilled. That can be dealt with, but getting the basket off the ground is more of a challenge.
I returned the 1.5" x2" adapter and picked up a mount for ATV Hitches that can be bolted to the ball mount that comes with the hitch. This may provide the lift I need. However, it could potentially rotate. I haven't played around with it enough.
Is anyone using a hitch mounted cargo carrier that is not 60" wide, and adapted to the small cruze hitch size of 1 1/2"?
If so how did you do it? I can return the aluminum basket, but I haven't found any other options that are less than 48" wide.
I have some pictures of the 48" aluminum behind the car, but it still needs some work if I keep it. Any welders in the Twin Cities, MSP area?
