My 2011 1.4t never burns oil
Sent from my iPad using Tapatalk
?? wait, what??..snipped..
I usually change it when the engine starts vibrating on idle with the AC on.
....snipped
The engine is running super smooth, no vibrations on idle, until the oil starts getting bad.?? wait, what??
Don't take this the wrong way (sometimes difficult to convey the way things are said via text on a screenThe engine is running super smooth, no vibrations on idle, until the oil starts getting bad.
Then, with the AC on, it idles a little tougher, and I feel it vibrating gently.
That's my indication of an oil change.
I think as far as a quart on oil every 1k miles is a lot of oil! Your engine will run dry in 5k miles.
A quart on 10k miles sound a lot even.
I'm at about half a quart, at 10k miles. They filled up my car at around halfway the dipstick, not full.
That seems reasonable, but not a good measure for oil changes, the reliability of popping the hood and checking the dipstick, when the car is warm and off, and how much time is required to do so make it the best way of checking your oil.The engine is running super smooth, no vibrations on idle, until the oil starts getting bad.
This is correct and helpful, I have heard this in other forums, Subaru and Mazda has it in their owners manuals too, it's true that it's "acceptable" and sometimes the norm for those cars (which run 0w-20) my wife's Mazda sees a lot of driving a lot of city and a fair amount of highway, maybe 65/35 and urns about 1/2 qt of oil. My brothers Subaru Outback runs 0w-20 and burns 1 qt, My pickemup truck burns a quart after 3000 miles at 195k on the odo with 5w-20 high mileage and Lucas Molasses in it. Burnt maybe 1.5-2 quarts without the molasses lolOil consumption, on the order of one quart per 1000 miles, is actually considered normal/acceptable usage for any gasoline powered vehicle.
You will have folks that report no consumption between oil changes, and then hear from others that experience their same make/same powertrain, similar mileage vehicle consume a quart every X miles.
There are many reasons for the variable experiences.
Although built on a assembly line, using the same parts and procedures, there are variables along the lines of piston ring gaps, for example....not always the same, but fall into the plus/minus range allowed for production. This variable applies to all engine components.
This explains why one engine consumes oil and the one that came off the line uses no measurable oil once broken in.
Driving style also comes into play.......an engine that experiences a great deal of high rpm operation has a better than average chance of consuming oil, but again, not always, likely due to the same variables.
A great deal of short trips can be a fooler too.
Short trips tend to create internal condensation......replacing oil consumed with water. The oil holds the condensation in suspension so you don't see a color change.....everything looks normal. Those short trips are adding unburned fuel from the rich condition of startup to the oil as well, thinning it and making it more prone to get past the rings and seals and be burned.
That same car, showing full on the dipstick after, say, 3000 miles, is now taken on a several hundred mile road trip at high speed.
The oil, with the mix of moisture and fuel, now operating a full temperature, boils off the accumulated moisture, lowering the level, and the remaining oil, thinned with fuel and sneaking past seals and rings, obviously lowering it further.
When you check the oil after the trip, you a find a quart consumed over only, say, 600 miles in this example.
Naturally, the first thought is something is wrong, when, in fact, nothing requires attention beyond a fresh oil change.
In most cases, engine disassembly and measurements will show everything within specification.......hence the '1 quart per 1000 miles' industry standard.
The stock oil was in there for maybe 5k miles (50% of oil use),You really should not be running the OEM oil for longer than 5k mile intervals and 1 year, whichever comes first.
Sent from my BlackBerry PRIV using Tapatalk
This is how my 1.4L/ 6 spd is. I only added a little when I changed the filter @7500 of 15K. I will be running 18K intervals this current change.I also go 15,000 miles on Amsoil SS and experience no loss of oil. I'm at almost 14,000 miles and the dipstick reads full.
