1 - 15 of 15 Posts
How much oil from PCV in intake is to much?
14,000 miles and there is quite a bit so much that there is a pool in each of the ribs in the intake after PCV.
Thanks.
I have no oil showing.
Thanks.
I'm confused.......Are you asking about oil accumulated ON the intake or IN the intake?
As I read your question, I interpet it it as ON the intake puddling in the strengthening ribs.
Oil IN the intake in the valleys of the Ribs just before the Turbo. Inside Not outside.
So the dealer says bellows full of oil is normal for the CTD. Any diesel mechanics have a comment on this? They also said this is how the Turbo gets lubricated!!! I looked at him and asked him to repeat this info. What The Heck!!
Discussion Starter · #11 ·
So I was speaking to a Diesel Mechanic over the weekend he said everything the dealer said was nonsense and to ask to speak to the diesel mechanic they have and ask one question and for them to check a data point should take 3 mins if he sees a problem then go from there.
So I will be going back to the dealer this week.
Reactions: pacolino
Thanks.
Hi there, do u have a picture to see how much oil is in there?
Sent from my LGMS631 using Tapatalk
Don't worry to much about oil comming into the turbo cold inlet. There is nothing to lubricate there; that's nonsense. Oil will however accumulate with the time, into the intercooler and that will lower its performance. You may try to drain it from there and see how much it really is. Tunned engines tend to blow more oil into the PCV and for them oil catch can is recommended. Watch your engine oil level btw, if it starts to drop significantly then that's something to worry about.
1 - 15 of 15 Posts
