How much paint do I need for a fender?
9494 Views 4 Replies 3 Participants Last post by  Blasirl
I was pulling out of my apartment's covered overhang and wasn't paying attention and managed to dent the passenger fender pretty well. Thankfully it's just the fender and the replacement panel isn't all too expensive and the replacement steps won't be horrendous. The problem is painted panels are almost x10 the price of the primed ones. In the name of frugality I'm going to try and paint the panel myself for experience and cost savings. My question is how much paint will I need for just the front fender and can I do it with just aerosol? Would it be worth my time to find someone with HVLP spray guns? Or am I in over my head? I'm decently mechanically inclined, but not so hot with painting. Thanks in advance.
the question is what quality of a paint job do you want? by the sounds of it you want what my paint supplier calls an "afar" paint job. it means it looks good from afar but up close you know a pro didn't do it. so to answer the title roughly 1/2 pint of paint will do it. but to do it right you are talking about 100-150 in materials assuming you don't have the cleaners, sand paper and will find a gun to borrow. and keep in mind the fender wont match the rest of the car exactly the right way to do it would be to blend the new paint into the surrounding panels. as for skill level i am a parts guy and paint all my own stuff i have never taken a course but i do a decent job. get friendly with one of your parts stores that supply paint and ask away. it seems over whelming at first but you tube can help take some stress out and remember you can always sand paint off if you don't like how it came out.
· Administrator
Not that I advocate using a rattle can, but you could probably do it with two if you use some cheaper cans for the inside of the panel. You still need to use the proper technique for spraying and will need to prep the panel as normal. Watch at least a few utube vids explaining this. I would also think about paint-less dent repair if you did not ruin the paint.
I did not watch these - examples only!!!
https://www.youtube.com/watch?v=_MsVWj3fGkY
https://www.youtube.com/watch?v=oHTui5yr40E
https://www.youtube.com/watch?v=-RxP-T8fTm8
https://www.youtube.com/watch?v=zFdjVe92e3E
https://www.aliexpress.com/item/Pro..._1&btsid=2bf5ab43-046b-4690-bc79-21aa6dd6f504
There is quite a bit of paint transfer on the fender, otherwise I was going to entertain the option of doing paint-less dent repair. I might go ahead and bite the bullet for a prepainted fender, just have to find a reputable supplier. because for the CAPA certified fender pre-painted might end up being a decent deal after I factor in my own time and labor.
