Sorry to hear about your luck. That's one reason why I've always gone SRI
YUP i am switching over to it ASAP..Sorry to hear about your luck. That's one reason why I've always gone SRI
Comprehensive covered it, and yeah. I am 22 yrs old, every penny i can save i get. After a month or two i am switching to another company and getting $500 deductible.What part of your insurance covered this? Also, you have a 1000 dollar deductable?
If i were to estimate i'd said 7-9 (max) inches, and the problem was also that as i tried to go through it, my car hesitated and didn't accelerate so it slowed down, and later it reacted and accelerated...So it was more prone to sucking it in..How deep do you figure it was in the middle?
Sorry man
I like that law....down here in southern AZ, when the monsoon rains "flood" just about every normally dry road crossing, there are many "dead" engines/cars sitting in the middle of flooded roads...and, some cars even end up getting "floated / washed" down the stream/arroyo for miles!
...so, the road people put up signs & close/block all the known flooded washes & roadways, and AZ has a "Stupid Motorist" Law that makes the owner who drives around those signs liable for all the costs of their 'swift-water' rescue.
...obviously, not the same situation as yours, but similar.
They should make that here, but there are so many little roads, and so many floods that i think its too big of an investment right now for the county/city. It would also help ALOT with insurance rates....down here in southern AZ, when the monsoon rains "flood" just about every normally dry road crossing, there are many "dead" engines/cars sitting in the middle of flooded roads...and, some cars even end up getting "floated / washed" down the stream/arroyo for miles!
Yeah i am just going to avoid them all together and back up.. Good information.. I know the sudden change in temperature can crack meta.. Unfortunately it is impossible to not find puddles here. (and i when i say puddles i mean real big ones)I don't do deep standing at all these days, but not for that reason. When a vehicle goes through deep water, the lubrication of the parts under the car can get flushed away. Links and brakes are mostly affected.And then the fan belt can slip. Possible fracture of the exhaust manifold. Just not worth it. And if there is ANY current at all to the water, then there is the danger of it pushing you off the road.
Wow yeah, thankfully you backed up. It would have probably gotten inside the cabin too maybe? I also waved off everyone behind me lol but some didn't listen and rubbed it in that they could make it -_-Sorry to hear about your misfortune... sometimes you just have to take it as reality badge & know next time you'll reconsider the choice of staying or going. I had a similar situation almost happen, but I got out to check the water level & poof I was knee deep! I waved off the two people behind me & said back up because I'm not going... they quickly reversed after seeing how deep I was in water. Oh I was driving my Isuzu Trooper so that is why I was able to keep the engine dry, but if I'd continued on I likely would have suffered the same fate. Getting back in was no fun... took off my belt & wrapped it on the steering wheel for leverage.
Now that you're back on the road... hoping your troubles are behind you.
I have also noticed the Cruze is lower than most cars.FWIW I have to constantly remind the wife that her '11 Cruze is much LOWER than her '87 Astro Van was...and, that GM makes cars not boats!
Good information, my mistake was misjudging the water level. And when it got to the mid part of the flood, my car decided to acclerated (i had my foot on accl) and it just sucked it all in.. I never heard a bang, but when the car tried to turn over it made horrible scraping metal noise. At that point i gave up lol.First off, if the water level is over the tail pipe, the engine rpm must be kept high in order to keep the exhaust pressure up, so that water does not go up the tail pipe and stall the engine. If this was to happen, it wouldn't likely do damage, but the car would have to be towed out of the water, and a modern car would likely throw a trouble code to the computer, causing the computer to have to be re-set. If you were able to drive through, then you didn't have this problem.
If the water level gets above the air intake while the engine is running, the engine could suck in water, and the engine could hydrolock, which means that water is sucked into the cylinders. Because water does not compress like air, water in the cylinders can cause severe damage that will require and engine rebuild or replacement. If water gets in the engine while the engine is stalled, the water will have to be removed before the engine is started or a hydrolock could occur. Remove the spark plugs and crank the engine, and the water will be pumped out of the spark plug holes. If your vehicle hydrolocked, you would know about it, because it would make at least one very loud bang, and would not continue to run. Since most air cleaners are near the top of the engine compartment, in most cases, the water would have to be more than a foot deep to allow water into the air intake.
Finally, if the water gets higher than the vents on your crank case, transmission, or differential, you could get water in your engine, transmission or differential oil. This would allow the vehicle to continue to drive, but over time, it could damage the vehicle. To check if this is the case, check the oil in each of these locations. if the oil on the dipstick appears milky, then there is water in it, and it should be changed.
Well the dealer covers it for 12 months or 12,000 miles, state farm covers the rest of the time. So pretty much i got anally raped with my warranty. Atleast i still have free maintenence for 2 more years, and that was included in my payments so..Reminds me when I was driving south on the Edens Expressway north of Chicago after a heavy rain. At an underpass, saw water, but could not see the surface of the road. I quickly slammed on the brakes, the guy being me started blowing his horn, giving me the finger, and was yelling at me when he passed me and shot under that underpass.
They found a used engine with only 8K on it? Vehicle must have been totaled, Cruze's haven't been around that much. How do you know it only had 8K on it? Did you see the donor and read the odometer?
With my claim, insurance company wanted me to straighten out the old fender, are you kidding? New one only cost 97 bucks, I got a brand new fender. And once sheet metal is crushed, no way to save it.
When I hear guaranteed for life, I don't walk away, I run. Usually talking about he life of a mosquito, about two weeks.
I pegged you older! Just a year younger then me, but I opted for 500 Deduct and I pay $125 a month now.. It just raised $15YUP i am switching over to it ASAP..Comprehensive covered it, and yeah. I am 22 yrs old, every penny i can save i get. After a month or two i am switching to another company and getting $500 deductible.
