Are the rear drums self-adjusting? I was under the impression that by using the handbrake while backing up would adjust the shoes one click at a time due to the "cam wedge" action of the shoes...I am not 100% certain but I do not believe you need to adjust the parking brake. Once the rear pads are changed, it should automatically adjust. It is not like the Gen 1 where rear shoes need adjusting.
Cables stretch.I am not 100% certain but I do not believe you need to adjust the parking brake. Once the rear pads are changed, it should automatically adjust. It is not like the Gen 1 where rear shoes need adjusting.
Thanks for this it's very helpful!I am not 100% certain but I do not believe you need to adjust the parking brake. Once the rear pads are changed, it should automatically adjust. It is not like the Gen 1 where rear shoes need adjusting.
Is this for the 2nd generation Cruze which has the foot lever next to the brake to engage the parking brake on and off? Or is this for previous generation with park brake lever engaged by hand behind the transmission gear selector lever?Pull the handbrake lever 'on' until slight resistance is felt at the lever; then try turning each rear wheel. Each should turn with equal resistance. If they do not, tighten the cable on the slacker side until both feel equal. Tighten the locknuts.
