I told you a clean & adjust would take care of that noise.
You did indeed! Thanks for that!I told you a clean & adjust would take care of that noise.![]()
Nice! I didn't even notice that, lol. Well, at least we have a dedicated how-to for it now that we can point people to when they come in complaining about the "brake catching" noise.I have described the adjustment of the parking brake a while ago….
It is true, you added excellent details!:eusa_clap:
http://www.cruzetalk.com/forum/9-ch...90-parking-brake-no-adjustment.html#post42089
When you take the drum off, you'll see what I mean. The locking plate is spring loaded against the adjustment nut. You can easily lift it with a finger. It doesn't so much as lock as it just keeps the adjustment nut from reversing on its own, identical to the "locking" mechanism on a ratchet.I need to do this but I'm a little confused about the "locking plate" and exactly how to slack off the adjustment if I go too far. Maybe you could add another picture and point to the place I need to press to release the lever that prevents rearward rotation of the adjuster.
Too bad the rubber plug on the backing plate doesn't line up with the star adjuster. I pulled it on mine but saw it wasn't anywhere near the adjuster so I put it back. I wonder how a mechanic would get the drum off in a high mileage car when the drum develops a lip at the edge. Somehow that rubber plug must come into play but it kind of baffles me.
I found the same thing. The drums got manually adjusted on my car within 1000 miles of getting it. That reminds me, it's time I did it again on both cars. It takes very little time the second (and third, and fourth, and fifth) time adjusting them.Nick, I and XtremeAaron tried this method of backing up and flooring the brakes, at least a dozen times each. No dice. It didn't do anything to solve this little problem of ours. The only way was to manually adjust the brakes.
Something is wrong causing the self adjusters not to work, by self-centering, I mean the shoe assembly has to be able to float. Should be able to put your hands on the opposite shoes, move it up and down and sideways. If not, something is binding or needs lubrication.Nick, I and XtremeAaron tried this method of backing up and flooring the brakes, at least a dozen times each. No dice. It didn't do anything to solve this little problem of ours. The only way was to manually adjust the brakes.
