When you push the pedal down, fluid squirts out. When you let up on the pedal. Air is sucked in. Pumping the pedal 20 times with the bleeder open is NOT a good idea.
If you pump the pedal a couple of times with bleeder closed. Bubbles build in the fluid.
Proper procedure is to push pedal. Open bleeder. Let pedal sink. Tighten bleeder and let up on pedal. Repeat till no air comes out. That's a 2 man job.
Another procedure that only involves 1 man. Is to use a vacuum pump and pull the fluid through teh bleeder with bleeder open.
Another producer is to use a machine that forces fluid into the master reservoir while it forces it out the bleeder when open.
Using a hose and empty container is a good idea. I'm sure the procedure can be done without a 19mm socket taking the tires off. However, if you use the vacuum pump method. There's a container and hose already connected to the pump.
I'd also recommend using a 6 point socket to loosen bleeders first. As them buggers have a habit of freezing up and you'll round them out with a wrench before you know it.
AND
google the correct order for bleeding which tires. I'm not sure if that order is still correct these days.
AND
