1 - 20 of 21 Posts
I looked all over at all the threads and there were so many questions about installing a boost gauge and no guides. So, I installed one tonight and here is how I did it.
NOTE: I used bag ties for now since I ran out of zip ties. I also used double sided tape to hold my gauge in place for now. I'll clean it up later.
I got a cheapy Autozone gauge that didn't come with everything, so you might need to get some things. I also got them at autozone. I didn't know what size anything was so I got a variety pack.
Plastic
1. Vacuum hose ends. They slip on the end of the vacuum hose so that you can fit it to the T
2. Rubber vacuum line. You don't NEED this but I didn't want to cut my stock stuff in case I had to go back in a hurry for some reason *cough*warranty*cough*
3. And of course, T fittings. These let you split a vacuum line.
Land vehicle Vehicle Car Engine Auto part
I already have this installed. I ran the line across the lip of the hood. There are 3 plastic rivets that protrude out and they have slits in them. I used them to hang the line. The line starts at the passenger side where it is hooked up to the vacuum line and ends at the driver side where it will enter the cabin.
Vehicle Car Auto part Engine
If you look close the line will go down behind the other lines that are there including the fat coolant line. This line is HOT if the car isn't cold. Go ahead, ask... Anyway, the arrow is pointing to a white spot. this is where I have the T.
Auto part Fuel line Engine Automotive fuel system Vehicle
This is a shot from where the strut tower is pointing toward the back of the motor.
#1. The black and green line. The end of this is now in the T, but it was hooked in to where the black line is now (#2). #3 is the vacuum T. #4 is the rubber vacuum fitting that I connected to the plastic vacuum line (#5).
Note: To remove the black and green line, just get a flat head and gently press down while pulling with your fingers from the other end. Be very careful. it's snug but don't force it off. try twisting it to help break it lose. If you break the nipple...well...just don't break it!
Auto part Engine Fuel line Motor vehicle Vehicle
Similar shot. #1 is the intake manifold. #2 is the coolant hose that leads into the cabin where it meets the heat exchanger (where you heat comes from inside). #3 is the alternator.
Auto part Wire
Ok, this is over by the fuse box, coolant resivoir and everything else. The hose is entering an extruded rubber peice. I poked a hole in the end from inside of the car.
PRO TIP: Push the line from inside the cabin into the engine bay. Much easier. Then grab it and pull it out and then run it over to the passenger side for hook up.
Auto part Wire Floor
This is inside the car on the floor looking up by where the clutch is (or a void area for you sissies. j/k). You'll see a fat line going into a rubber boot. Where the line is coming out in this picture, jam a screw driver in there to poke a hole for the line to run through.
The line from here is running up to the fuse box area.
Electronics Technology Electronic device Electronic component Vehicle
NOTE: This is where I chose to route my line. You can stop here if you like and route it however you want.
There is a hole in the metal bracket that is perfect for the line to go through Routing through this hole helps keep the line out of the way of the other moving parts (especially for those with clutch pedals). From there I ran it under the steering wheel and up to the other side where the stereo is.
Vehicle Gauge Car Speedometer Tachometer
If you follow the green line, you'll see where I routed it. Just line it up and slip it in the cracks. You can gently push the line inside to hide it.
I have not yet run the power. Going to do that right now.
PRO TIP: The plastic vacuum line will be all coiled up and such a PITA to work with. To fix this, boil a pot of water. When it's boiling, turn the flame off and drop the hose in the water for 30-60 seconds (doesn't take long). You'll see it uncoil. remove it from the water and stretch it out (don't force it). Get it as straight as you can and let it cool off. It will be much easier to work with now.
Electrical
+12 constant = #14 fuse
Keyed on hot +12 = #6 fuse
love how you ran your tube, mine is wraping around near the coolant over flow:uhh:... where were u a few months ago when i figrst installed mine.. haha owell great write up! looks great
I was about to route the line the same way but I noticed the plastic rivet ends and was like SWEET!
WARNING: I'm not sure if a clamp would help this but the **** vacuum rubber fitting split under the boost (22 psi).
Gun Firearm
That blows!!!! I just have my boost line into my charge pipe w/no vacuum reading :/
I WOULD have gone with that since autozone only had a BOOST gauge (not vacuum/boost) so I can't read vaccum. but the line is installed and I can swap that POS gauge out later with something else.
However, I need to find a way to fix the vacuum fittings from splitting.
My wife was like, "Why aren't you boosting? I boost no matter what I do!" and I was like, "OMFG why didn't I install the ejector seat yet?!"
Seriously it must have split after my 2nd pull. WTF?
Similar thing happend to me after i tuned. The #2 Line kept blowing off the line it's connected to and i ended up having to zip tie it down.
I'm dealing with that right now too. I had to ditch the vacuum fittings and use another piece of solid rubber line and some clamps. PITA!
Reactions: Jnoobs
Yeah it was a PITA. The zip ties i bought were to big so i used these tiny ones that came with my friends HID kit.
Discussion Starter · #11 ·
Are we sure there is no boost reading in the DIC? I know on my Cadillac there were readings that didn't show up unless you knew the codes to put in to activate them. Just curious.
Maybe in the newer models but according to the experts (like the people who tune them), the data isn't available on the bus and last I heard, could not be put there.
I have a bluetooth OBDII adapter and the Torque app on my phone. This shows me Boost/Vacuum. Granted I haven't really done anything with this but it seems accurate as the boost goes up as I increase the throttle.
Anyone have experience with this setup on our Cruze's?
Discussion Starter · #14 ·
Unless you have a fast adapter I wouldn't trust it. I've read the ELM 327 (and similar) units are too slow to be of any use except to satisfy the novel curiosity. If you really need/want it just get a nice gauge. I recommend on that reads -30 to +30. The install isn't that hard and decent gauges can be had for ~$50 online. If you just want to log, then get a good OBD2 adapter.
It reads pretty close to my actual boost gauge, but it does lag a bit, which is why mechanical boost gauges are best.
Discussion Starter · #17 ·
total noob question, what line do i tap into and where is the best spot to tap into it? i have a '14 1LT M/T.
Did you see if you have a similar setup to the pictures in the first post? Look on the passenger side, behind the motor/under it for a black hose with a green stripe. Tap into that one. If you don't have it then I don't know, but there are other places to tap like the intake ducting, but I don't recommend that.
ok thanks ill take a look. there were a few changes made with the '14. one example is when doing the resistor removal there is no black pipe/hose connected to the lower part of the air box, and the rubber gasket/rubber connector between the air box and the lower piece is larger and sits against the body frame, much different than the small rubber gasket,connector between the two.
Hi guys . Why you are install this way with the T . Simple and other are installing it this other way more complicated with special fitting . See picture of fitting and where they install it .please help me I want to put my vacuum gauge at the best place and my boost gauge too .I got both .where tap and how each gauge I have .ñrovide me picture please ...
1 - 20 of 21 Posts
