Do you happen to own said tool?
I doDo you happen to own said tool?
sure...I'll make a template on paper and measure that out for you. Can post the info tonight. But honestly, by the time I do that, you get the measurements and you make the thing, amazon would be a day away from delivering the real deal..lol. I'll help you out though and will post the measurements.Is there any chance you could measure the important points that it touches on the cam phasers ?
as long as you print it to actual size, it will work...I just wouldn't want you solely relying on that to make your own...I'll include some measurements for you as a reference pointThank you so much!! It fits on a piece of paper, perhaps you could just trace it to make the template, and then scan it if you have a scanner? Then I could just print it out and fabrication is very straightforward from there
you mean the crankshaft locking pin? The big T45 or 50 plug, whatever it is. Should be easy enough to access and drill it out or weld a nut to itAny suggestions on getting the plug out for the camshaft locking pin? I used the right torx bit, but it stripped out and won't budge.
