I have experimented with DFCO and know it will engage from slightly over 1500 RPM all the way up to at least 5000 RPM when you let of the gas for more than a couple of seconds. The injectors are restarted whenever you put the clutch in (manual transmission only), you step on the throttle, or when the engine speed drops to 1200 RPM. You can DFCO in action by switching your car to Metric and watch the instantaneous fuel economy drop to 0 L / 100 KM.Is this a proven fact? Not going to lie but I feel like such a retard doing this going down hills and such, lol.
DFCO won't coast as far as neutral, but in many instances its a better solution for coasting than neutral. Whether to use DFCO or neutral depends on how far you are going to coast and what you will be doing at the end of the coast. I have discovered that when not changing gears at the end of the coast I just use DFCO. If I need to downshift sometimes I'll use DFCO and other times I'll make a long slow shift and coast with my clutch on the floor. If I'm stopping I'll use a combination of DFCO, downshifts, and coasting once I get too low for 3rd gear. Coming down the side of a mountain I'm frequently in DFCO in 3rd gear (this is how I know it works to at least 5K RPM) and use the brakes to keep my speed below what the Colorado State Patrol will allow for downhill traffic.
