Awesome that they just removed the light but left the wire! Haha, makes this a pretty simple install.
Thanks for this writeup!
Nice post & great pics! So... now the big question inquiring minds will ask. What is the bulb type... you know to replace it with an LED equivalent?! :goodjob:It was talked about, and i did miss the light in my 2012. So i took the light out in my 2011 and wrote down the part number on it (13503057 F-lamp) and headed to the dealer. Yup its a good number, also used in various other models. It was $7.62 + tax of course, it took 6 days to get it to Minnesota.
It was talked about, and i did miss the light in my 2012. So i took the light out in my 2011 and wrote down the part number on it (13503057 F-lamp) and headed to the dealer. Yup its a good number, also used in various other models. It was $7.62 + tax of course, it took 6 days to get it to Minnesota.Also what kind and where did you get the light, not just the bolb? Is that the OEM glove box light and bulb?
I work midnights and installed it after work and completely forgot about the LED bulbs i had. I just popped it out and it was a 106 bulb (same as the rest of the bulbs in the car) I swapped it out with a led bulb. I got my 10 pack on eBay just search for this on eBay. 10x T10 W5W 194 168 501 Car White 20 SMD LED Inverted Side Wedge Light Bulb 12V
Sorry i dropped the ball, here are a few pics.No sweat Silver... you know come to think of it & holy duplicates Batman! That is the exact same part in the 2012 trunk!
Thanks for the pics... it looks great installed... maybe I'll ditch the hockey puck 3 LED stick up I put in my glovebox & jump on the real deal.
Interesting, just assumed our 2012 2LT didn't have a glove compartment lamp because our 04 Cavalier didn't have one either. But somehow we survived.
Noted the same cutout that you described. Also found the part on gmpartsdirect for $5.41, that was good, but the $12.58 S%H charges weren't.
Ha, will have a meeting with my wife to see if she wants one. First part of your instructions does a nice job of showing how to check the cabin air filter.
But do wonder about that black and white wiring harness, is that always hot or connected to the BCM in some way so that if the door is not close, could discharge the battery. Kind of like crawling inside of your refrigerator to make sure that light goes out.
Could start a post on what do you keep in your glove compartment. Our 04 was jammed with CD's but using MP3 USB drives now. So it is pretty much empty. Could throw in a pair of gloves.
It certainly does, just with a switch...That light lens/socket looks like the same exact one in the trunk. Good install.
So it started the install.
Start by taking the Glove box out, 1st there is a spring loaded cord on the right side, open the box all the way and grab the cord and then lift up on the box to give it slack and the turn it sideways to get it out. Then just grab both sides (inside) and pull them together gently until it clears the clips, then just take it off the hinges.
Next is to take out 3 bolts out to gain access, there are two on top and one on the side.
Now you will be able to pull it down to see when you cut it out for the light. From the right access cover reach in and grab the WHITE taped up power wire for the glove box (Thanks GM for not deleting that)
Now its time to cut out the block, I used a Utility Knife. Inside the box you can see a square box and when you look on top of the box you can see again a square box. cut that out. Its about 2 1/8" long square.
Now its time to drill a 1/4" hole for the button. I drilled the hole so there is 1/4" gap of plastic
Now slide the power wire threw the hole, plug it in. Only goes one way. Then install the light, slide the black button in first and line it up with the hole and snap it in place.
Now you have a glove box light, bolt it back up and your done.
