How-To: Install Fog Lights WITHOUT Removing Front Bumper
91083 69
Go back to COMG- The Cruze Owner's Maintenance Guide
I just got done installing GM fog lights on my '12 Eco and figured I would share how to do it without removing the front bumper. There are a couple other how-to's on this site that show how to do it by removing the bumper. For me that just wasn't an option, and IMHO is overkill. I am going to apologize for the bad picture quality up front. All I had was a cell phone to take pictures with.
Parts 1 through 7 are mainly concerning how to install it without removing the bumper. The remainder of them are generic to any fog light install.
You will need;
- T20 torex (for the front splash shield).
- Wire cutters/fork/something with a small edge to take the plastic inserts off.
- Philip screw driver.
- Small ratcheting wrench + 10mm + 1/4in sockets + 3in extension.
- Car ramps or a lift. I used wood ramps.
- Fog light kit (of course).
- Small hands is a plus.
Before starting make sure you disconnect the negative battery terminal, and the car is safely secured on the ramps or lift. I am not taking any responsibility for anything that happens to you or your car (or anything else) from following this.
1. Remove the front splash shield under the radiator.
There are a bunch of T20 screws that hold the front of the shield on highlighted in blue. These are easy to take off. There are 2 in the center that do not need to come off but I took them all off anywho.
The line in red are the plastic inserts. I used a flat head screw driver to get them started, then a wire cutters to get on both sides and pulled. They pop off pretty easily.
The green colored lines will need to come off also, but I did those later when I was installing the fog lights.
Lastly, the yellow arrow is the direction to pull to remove it. It should be self explanatory once you are doing this yourself. Basically just pull down and to the back of the car.
2. Remove passenger side non-fog light insert.
Once the shield is off I started with the passenger side first because it looked easier (and was). Removing the original non-fog light inserts was kind of tricky, but once you get a look at it things make sense. There is one screw holding it to the bumper. The 3" extension helped with getting more swing on the wrench.
3. Install the passenger side fog light.
This is pretty straight forward. Re-insert new fog light cover the way the non-fog light one came out. Once the insert is in place the actual fog light can be fitted. The fog light will slide right up there no problem. Once in there you can tighten down the two screws that go on the same side, or towards the center of the car, to hold it there while you get the third on the far outside. I used a wrench with a 1/4" socket and philips bit.
This step is where the small wrench comes in handy with an extension. The outside screw is in a place that is hard to reach, but it is doable (more doable than the driver side). This is also where I removed the screws/plastic inserts on the green line from the first picture. That allowed me to pull the extra plastic flat down (which is also part of the wheel well plastic) so I could get more of my arm behind the fog light.
Here it is installed.
4. Remove the driver side non-fog light insert.
It will come off the exact same way as the passenger side. For the temperature sensor I used a 10mm deep socket and pushed/gyrated it around the front side of the panel to pop the temperature sensor free.
5. Insert the driver side fog light.
The front panel and temperature sensor are another straight forward install, especially if you did the passenger side already.
The trouble comes from trying to screw in the outside far screw to secure the fog light to the bumper. This is where small hands is useful, and you will have to remove the screws/inserts in green from the first picture for this side. You just won't have enough arm room to get at the screw otherwise. I can't really explain how I got my hand up far enough, let alone with a ratchet, so I took a picture. Once all 3 screws are in you are finished installing the fog lights, and then on to the harness :)
6. Install the harness.
The harness is routed around the front of the car, next to the rest of the wiring that goes to the passenger side. There is a hole on the passenger side that the wire goes and drops down to the fog light.
The driver side has to go behind the headlight and the fuse end splits to the fuse box.
I attached the ground to one of the 3 posts that are to the inside of the driver side headlight. Then go back to the fog lights and plug them in.
7. Reinstall the splash shield
You should be done underneath the car now. Reinstall the shield the way it came off.
8. Install the switch.
Easiest part of the whole thing. Pop the fuse panel cover off below the switch and push from behind. Replace with the new switch. Sorry, no picture :)
9. Install harness to the fuse block.
Take the fuse cover off. The fuse you want is #48, 15A. There are three large stainless screws holding the whole thing down. Once they are loose you can wiggle the top portion off by unsnapping it from the 6 tabs on both sides. The fuse block top then wiggles off and you should see a bunch of holes where the fuse tabs would slide in to. There is only one end of fuse 48 present, and by comparing to the backside of the top you can figure out where it is suppose to go. The harness plug can be stubborn to get in the fuse block. I used a pointed needle nose pliers to make sure it was in all the way. Once finished, reverse the process to reinstall the fuse block. Again, sorry, no picture.
10. Do one last sanity check, connect the battery terminal you took off, and test them out :)
Hope this helped!
61 - 70 of 70 Posts
So...as I read this that was only a period of time in the 2013 production run that NEEDS programing, Does that mean a 2014 does or does NOT need programming? I really want these but I don't want to spend a Saturday waiting for a reprogramming at the dealer after I spend one putting this together and manage to get a weekend appointment.
Got the kit from ShopChevyParts.com today and put the interior switch module in my 2014. The fog light indicator came on in the gauges but I will install the full kit tomorrow after work and confirm that everything else works as well. Looks promising so far. I really do not want to go to the dealership either.
Mine was built in Septmeber 2014, ordering my oem fog lights tomorrow. Happy I wont have to reflash the ECU.
I've found multiple different item mumbers for 2001-2014 Chevy Cruze fog lights
95469569
95248415
95903470
Does it matter which one you buy?
I found the 95903470 version on Amazon for $172.79
One source says 9546956 was replaced by 95903470. Another source says that 95903470 was replaced by 95248415.
I do know they come in "all black" and "black with chrome trim". But all the pictures I've seen are "all black".
Thanks for the response. I don't get why they all have different part numbers. They seem to be interchangeable as long as you have a 2011-2014 Cruze
Great...I ordered a set of fog-lights for mine knowing I shouldn't have to waste half a day and pay to have it reflashed to work.
Just wanted to be another to confirm...my 2014 Cruze diesel ( I do not know the build date at this time) did NOT require a reflash for the fog-lights to work. Installed mine yesterday.
Pics to show some of the things to deal with when doing the fog lights.
The red arrows show the 6 clips you need to release to pull the top of the electrical center out. It also shows the 3 bolts that retain the connectors to the electrical center.
Another view of one of the clips.
The battery side of the electrical center.
Tab that holds the connectors in the base of the electrical center. This is what I mentioned previously. Lock them into the base and you don't have to fool with getting them aligned to get the top back on.
Shot of the connector locked in place in the base.
Arrow shows an example of the terminal retainer that help hold the wiring in the connector.
Here is the actual retainer that you remove to make adding the wire easier.
This is was happens when you tired and in a hurry. See the red arrow, that is the wrong location. It should be in the cavity above the purple/gray wire.
Now they work great!!!
I looked at your picture and put the fuse in the wrong spt and now i cant get it out. Any idea how to get the wire out to put it in the corrf terminal. I feel like a moron
If you put the new foglight insert in AFTER you put the foglight in. You have extra work space as you can get fingers in trough the front too. And have more light.
61 - 70 of 70 Posts
