too many photos so heres the rest
i turn on my turn signal in my car and check the voltage,set your voltimeter to 20v
so starting from the black wire (ground) to the center plug and i got a voltage of 6.88
and it then jumped to 10v so this is the rite one!
prepare your quick splice and see where you wanna put it
one end of the resistor and the black (ground) rite and CRUNCH it in
do the same on both. and the other end of the resistor goes to the center wire on both plugs, this is the turn signal positive wire
now that both ends of the resistor are crimped into place you are ready to test, don't button everything up just yet, make sure everything works properly before you put everything away.
and thats it , tape it all up nicly with electrical tape and put everything back to its rightful place
hope this helps
video of results will be on here tonight
http://www.youtube.com/watch?v=GkYtPXaKKqE
ask questions ill answer
hope this helps
