1 - 17 of 17 Posts
· Administrator
Overview:
This is an extremely easy, satisfying, inexpensive modification. I ordered my Diode Dynamics 921 LED bulbs in the XP50 flavor. They are rated at 410 lumens which is significantly brighter than stock. (Anyone know the stock lumens?)
I asked Nick a few questions and then placed my order. I happened to order on Black Friday and received a healthy 20% off. If you don’t want to wait for BF this year, he does offer free shipping to US Cruzetalk members. I received them within a short time, so quick in fact I did not have time to install them right away.
If there are any questions, please ask, I’ll answer as best as I can and if needed I will modify the tutorial. So let’s take a look at my K-town Cruzer…
Tools Required:
- cross tip screw driver
- small flat tip screw driver (tweaker)
- a piece of small gage wire
- micro fiber cloth
Parts Required:
- replacement bulbs
Procedure:
It happened to be warm right after Thanksgiving, so I made time to install them. It was a breeze to do so.
1. Order and receive the DD XP50's.
Lighting Automotive lighting Technology Electronic device
2. This is a side by side comparison
White Light Yellow Automotive lighting Light bulb
3. This is the tools I used EDIT: I found a thin towel works even better than the wire.
Metal
4. Pop open the screw caps
Vehicle door Car Vehicle Auto part Automotive lighting
5. This is a close up of the caps and its clip
Door handle Plumbing fixture Door Room Lock
6. Remove the screws
Red Yellow Door handle Wheel Lock
7. Gently ease the wire behind the tip of the tail light housing. I would use a plastic pry bar if you have a hard time starting the wire. I made the mistake of using the small screwdriver to pry and ended up scratching my paint – even though I knew I wouldn’t.
Red Bumper Automotive exterior Magenta
8. When you get about this far, gently tug on the wire and with the other hand, near the screws you removed, pull at the same time. You are popping two pins out of their rubber socket.
Red Automotive lighting Automotive tail & brake light Vehicle Car
9. This is what the removed lamp looks like. I also twisted out the reverse light.
Auto part Vehicle Fuel tank
10. Now is a good time to wipe out the accumulated crud to help with rust prevention
Vehicle door Auto part Vehicle Automotive exterior Car
11. Now install the XP50’s. You may have to try a few times so test that the lamps light before you put everything back. If they do not light, try rotating them 180 degrees. If they still do not light, you may have to move the bent wire either to the left or the right and try again.
Auto part Wire Gas Automotive fuel system
12. This is a shot from the side after the install
Red Light Orange Automotive lighting Floor
13. This is a shot from the back - they look like headlamps. The two orange balls at the top are actually street lamps.
Automotive lighting Light Headlamp Mode of transport Night
Don’t they look just fantastic! If you have tinted windows this will make it easier to see for sure.
Another mod well done! :eek:ccasion14:
I use the "arm" method of removing the lights. Using the side of my arm against the side of the light housing. I use the arm to hit & drag. It may take a few tries, but it works for me. The idea is to "pull" the housing straight back. There are guide pins that prevent it from moving any other direction. What you have to do is break the seal of these guide pins so it will start to slide. That's the idea behind the "hit" - to provide a shock to the seal and and provide a push/pull to move the housing backwards.
· Administrator
My luck and I would crack the housing.
· Administrator
You're not supposed to hit it that hard. Besides, unless you have arms of steel, you're not going to hit all that hard with the side of your forearm anyway.
You missed the "My luck" part:banghead:
I installed some very similar looking bulbs in 2015 but they were not very effective with my tinted windows. Mine are probably no where near as bright since i paid like $30 for 3. They were the brightest I could find at the time for that small of a socket. I debated installing a bigger bulb and making an adapter but did not want to modify the housing. Also debated some aux reverse lights or a backup camera.
Those bulbs seem like the ticket except for that price. I paid that much for my dual beam LED headlights and they are rated at 3500+ lumens. OPT7 fluxbeam or somthing.
· Administrator
Discussion Starter · #9 · (Edited)
You get what you pay for. These fit well and throw no codes and are very bright, bright enough to help, but not completely overcome, the tint. They are also warranted for three years
[h=1]Chevrolet Cruze Reverse/Backup LED Bulbs! Plug and Play! Big Increase in Visibility![/h]
· Administrator
Will be doing mine soon as this cough/cold go away and the weather cooperates. Love the look, just not liking that $$!
So did you ever finish this? Any Pic's?
· Administrator
Discussion Starter · #16 · (Edited)
(Although we are in the 1st Gen section.)
Sent from my Pixel 2 XL using Tapatalk
Well, you know, we don't mind ... occasionally anyways! :rolleyes:
1 - 17 of 17 Posts
