Parts you will need:
All are GM part numbers.
Switch pn: 15853223
Bezel pn: 15853222
Connector pn: 12102900
(be warned the connector was 3x the cost of the switch and is not needed.)
Find a location suitable for you to install the switch. I chose the glovebox because it is hidden and close to the BCM.
I had to modify the switch because I didn’t want to spend extra on a connector. I trimmed the back of the switch to gain access to the terminals.
The terminals you will want to use are A and C. I soldered the wires directly to the terminals. The other two terminals can be used for lighting the switch if you want. It will light red as I sourced the switch from an 07 pontiac G6.
Drill a hole large enough for the trim bezel.The retention tabs on the bezel should sit behind the panel without intruding into the center. There is a raised portion on the bezel that indicates the top.
Feed your wires and switch through. Push the switch in to place, it should click and be flush. It has a very specific location to make it sit flush.
Remove the trim panel on the left of the passenger footwell to gain access to the bcm.The connector is pink, the wire is yellow with a dark blue tracer. I used a scotchlock (even though I detest them) to connect one side of the switch. It does not matter which terminal on the switch you connect to the signal wire on the BCM.
Run the other wire to a suitable ground. Your switch should pop the trunk like the button on the trunk when it is connected correctly.
Re-install any panels you removed and you are done.
Switch pn: 15853223
Bezel pn: 15853222
