Go back to COMG- The Cruze Owner's Maintenance Guide
This tutorial is only applicable to Cruzes manufactured in mid-2012 and older. All 2013+ Cruzes will require a relearn tool to correct the TPMS sensor locations.
The TPMS sensors can also be matched to each tire/wheel position by increasing or decreasing the tire’s air pressure. Personally, I start this procedure by inflating the tires to the maximum as shown on the sidewalls. You will see why when you do the matching process. Also, if a horn chirp does not sound after 35 seconds for any of the 4 sensors, turn the ignition OFF to exit the learn mode and repeat the procedure from step 1.
1. Set the parking brake.
2. Turn the key to run (do not start the car).
3. Using the control on the stalk, press the menu button to get to your tire pressure readings.
4. Press clear to reset. Your horn should chirp twice.
5. You have 2 minutes to match the first tire/wheel position and 5 minutes to complete the procedure.
6. Start with the driver side (left) front tire. Deflate the pressure until the horn chirps. Yes, the pressure will get really low, which is why I inflate to max before I start. Also, it takes a few seconds for the system to catch up.
7. Move the to passenger side front tire. Repeat.
8. Move to the passenger side rear tire. Repeat.
9. Finish with the driver side rear tire. When complete, the horn will sound twice.
10. Refill your tires to whatever pressure you run (I'm staying away from this one).
One thing that I noticed happened to me twice is that when I got done, the Engine light came on. However, after driving the car, it turned itself off. Not sure what causes this. Also, I noticed that when the engine light was on, the remote start did not work. Again, it resolved itself with no issues.
Hope this helps.
Hope this helps.
