1 - 16 of 16 Posts
So, you're new to your Cruze, or new to DIY'ing on your Cruze. Need to do something like add windshield washer fluid or check the oil? First, you need to get that hood open!
DISCLAIMER: This how-to is provided for informational purposes only. Neither I nor CruzeTalk have any responsibility or liability for any injury or damages resulting from following this how-to.
Tools needed:
Two hands
Optional: a set of gloves
Step 0: Unlock and open the driver's side door.
Step 1: locate the hood open latch. It's under the driver's side of the dashboard, to the left of the brake pedal. In the picture below, it's the piece of plastic with the car symbol on it.
To open the hood, slide your fingers behind and firmly pull out. The handle will swing up and stop. Stop pulling on it once it stops. While you're pulling, you'll hear a faint "pop" coming from the front of the car. That's the latch releasing the hood, and is perfectly normal. Don't panic, nothing's broken!
Step 2: Move to the front of the car. Turn to face the windshield. To open the hood, you will need to feel around for a small square tab underneath the hood. Place your hand underneath the hood immediately to the left of the line in the hood.
This is the tab you're feeling for:
Next, move your hand slightly to the right. You should feel the tab. Press on it, as in the photo:
While pressing on the tab, take your free hand, slide it under the hood, and lift the hood up. Careful, it's heavier than it looks! Keep holding the hood up with one hand while your other hand goes about freeing the prop rod that will keep the hood open with no hands.
This is the prop rod you're looking for:
It swings up and to the left to a plastic-lined slot in the hood:
While you're holding the hood open with one hand, grab the prop rod with the other, free it with a gentle upward tug, and swing it up to slip into that plastic slot in the hood, like so:
There you go! The hood's open, and won't fall down on you while inspecting the engine.
To close the hood, follow these directions in reverse.
Reactions: obermd
Not sure if I should say Thank You or WTF? Glad to see you have a sense of humor.
· Administrator
really!?!? lol
ooohhhh!!! so thats how you do it!!..........................................................jk
This shouldn't need responding, but since it does, I'll try to be polite about it.
I've walked into more people than I care to count that have no idea what they're doing when it comes to cars, just like some people have no idea what they're doing when it comes to computers. I had to teach my sister in law how to open her hood and check her oil. She's the kind of person who doesn't notice when there's a wheel-sized patch of leaked oil on the ground (dirt & gravel) where she parks.
There are plenty of people out there who would benefit from having a tutorial to describe simple tasks to them. Let's not belittle those people. There are many people out there who haven't the slightest clue how to do anything automotive related, and rely on their dealerships to do their inspection to make sure everything is working correctly. I personally know of people who have never opened their hoods in their life. I know of people who have brought their cars into the shop for a brake change because their pads and rotors are metal-on-metal on all 4 corners. To us, that's dumb, but to someone who doesn't know, it's confusing.
Consider that sciphi took the time to thoroughly describe a process he might consider elementary and perhaps mundane in order to empower someone to perform simple tasks they may not otherwise have been able to. If you have something to add or a recommendation to make respectfully, please do so, but don't troll someone else's efforts, especially when no similar efforts exist on your part.
In other words, if you have nothing to contribute or no sincere thanks to give to someone who made an effort to help other people, move along.
How true. My neighbor tries very hard to make it happen with her car and yes she finally asked me how her car hood opens on her Toyota it seems she always takes her car to the dealer for all service and also stops at The Auto Zone shops to have the fluids looked at and topped off which they will do for you. I showed her what to look for and how to check the fluids at least once a month. I have been at a few gas stations and have seen quite a few owners trying to unlock the hood to do a check it happens. I once saw an owner pouring antifreeze into the windshield washer I walked over and reminded him to not use it till he had it drained out.:)
XR chill out we were just having a little fun. I guess we should have asked the OP if he was indeed serious or was it just a parody???? If he was serious; then my apologies to him. But you seem to be alot more butt hurt about then he does.
· Administrator
Check the COMG sub-section under Mechanical. He has a post there explaining his intentions to create this thread.
I've been a bit annoyed by some of the comments made by specific members around here, especially in response to other members who actually put some time and effort into making this forum a better and more helpful place. Your comment didn't bother me as much as the last one did.
If the length of my post comes off as an indication that I took it too seriously, keep in mind that I type at 121 words per minute (corrected, after a 94% error rate at a higher speed), so what looks like a large post really only took me a minute or two. It doesn't take me much effort.
Sent from my Bulletproof_Doubleshot using AutoGuide.Com Free App
We're cool, When I saw his other How to thread I realized that he is serious and thanked hom for his efforts.
At first glance I might scoff at this post, but who knows, there might be someone who has the Cruze as their very first car. Everyone has to start somewhere. If that someone has XR and sciphi as references, then more power to them. I've learned a good amount from these two people. Even if this post is meant to be funny, it's a reminder that we all started somewhere!
Discussion Starter · #14 ·
This is a very serious thread. There are those folks out there who don't know how to do this, believe it or not. I can't begin to count how many times I've asked somebody a car question, and they don't even know how to open the hood.
The other target is new owners who have no idea where the hood latch is. Some cars and trucks have wonky hood latches that are hidden in places only a Soviet engineer would think made sense.
Don't laugh guys; this post is very useful. The other day at a car show it took me quite a while to get the hood open on a Mini Coupe. My friend (who drives a Mini Clubman) had a difficult time also. As someone else (XR?) recently said, it's like explaining computer basics: to most of us it's old hat, but some of us may need it.
· Epic Beard Man
Omg broke a nail opening hood to check oil with toilet paper! Be careful guys!!
1 - 16 of 16 Posts
