1 - 20 of 25 Posts
· Contest Manager
This thread will show you how to remover the headliner.
Difficulty rating
7 there are many screws and you will need around 2 hours to take off and put back together
Skill required rating
3 there is not alot of skill required in this prodject. mostly pulling, unscrewing, and tool/screw placement management.
Tools Required
small and skinny Flathead screw driver
needle nose pliers
torqx t20 bit
5/16 socket
Disclaimer: Please read all direction throughly prior to attempting. For electrical safety; disconnect battery by disconnecting the negative terminal. Wait 15 minutes before starting to allow all excess electricity to disapate.
To start you will want to pull off the pillars. Start at the top and give it a nice tug.
Technology Hand Electronic device Auto part Gadget
once the top section pulls out far enough you will see that the top is conected buy a hanger clip.
Hand Finger Bumper Material property Automotive exterior
to get the clip off the pillar push the latch and slide the clip off.
Razor Finger Hand Nail Nail clipper
from here you can pull the pillars out and lay them on the dash so theres no need to disconect the tweeters.
Vehicle Car Mid-size car Driving Center console
Next you want to remove to plastic cover above the rearview mirror. just push the center and pull each side out.
Bumper Automotive exterior Vehicle Car Auto part
· Contest Manager
From here you are going to the visors. Use a smal flat head to get under the disk covering the screws and move the disk out of the way.
Ceiling Vehicle Car
from here remove the three screws and place them where you wont loose/mix them up.
Helmet Personal protective equipment Auto part Sports gear
Now in this slot there are two clips that need to be squeezed together and pushed through utilizing the needle nose pliers
Technology Photography Auto part Electronic device Audio equipment
use your small flathead to lift the cover
Finger Hand Cable Technology Electronic device
and remove the only screw inside and it pulls straight out
Finger Gadget Electronic device Technology Material property
· Contest Manager
to take off the map light trim just get either your flathead screw driver or use your fingers under the trim and pull it all the way around until it comes off.
Vehicle Car Mid-size car Sport utility vehicle
same principle for the clear lense
Finger Electronics Hand Technology Gadget
remove the bulbs and the single screws on both sides. just leave the rest sitting in place and we will come back to this part.
Electronics Technology
to get the handles off lift up the covers using a finger or the flathead. once its open notice that it holds the handle down this will make reinstallation much easier.
Vehicle door Vehicle Car Automotive exterior Auto part
once you remove the screws. lift up on the handle and pull it out. now place those screws back in their holes and close the covers. now you wont loose them ;)
Car Vehicle door Vehicle Automotive exterior Family car
this is what your left with.
Vehicle door Automotive exterior Car Vehicle Auto part
· Contest Manager
ok getting back to the map light housing. from here you should be able to just give it a tug and come right out.
Auto part Vehicle Automotive exterior Tire Automotive wheel system
now you need to take out the long module
Vehicle Car Auto part Subcompact car Family car
like this
Automotive exterior Bumper Technology Trunk Electronic device
and disconect the other one. there is a tab you need to push to disconect
Tire Automotive tire Auto part Hand Bicycle handlebar
now these are the rear handle bars.
Vehicle Car Automotive exterior Vehicle door City car
same process as before. remember to save those screws!
Finger Power plugs and sockets Technology Electronic device Hand
· Contest Manager
we are now moving to the rear quarter panel. use your flathead to open the cover and remove the screw.
now another grab and pull
Hand Arm Finger Gesture
now lay it on the rear deck
Automotive exterior Bumper Vehicle door Auto part Windshield
these are plasic pop rivets. just pull them straight out.
Light Ceiling Skin Room Hand
this is the front seat belt cover. you want to pull out the top black section with the tan section attached.
Light Hand Finger Shadow Room
now you need to separate the tan from the balck. on the inside lips there are tabs.
Loudspeaker Audio equipment Subwoofer Computer speaker Light
now while keeping the bottom half of the black section attached to the car. let the tan section dop down and remove from the top liner. now move it to the side.
Vehicle door Vehicle Tire Automotive exterior Car
· Contest Manager
these 3 steps arnt nessesary but it will help you in the future.use you flat head to remove the clear lense
Technology Electronic device Finger
as well as the switch
Electronics Technology Hand Automotive lighting
and be careful with the reflector, its plastic Light Automotive lighting Headlamp Bumper Auto part
now back on track. from here all you have to do is lift up on the linner and get ahold of the edge of the dome housing and just pull it straight out. Technology Electronic device Metal Rectangle
the housing and the liner stay as a whole Electronics Technology Electronic device Electrical wiring Electronic component
· Contest Manager
and your done
Automotive exterior Vehicle Automotive design Font Vehicle door
Note* those square patches where added by me so you will not see them in your car
They are CDL tiles for sound deadening
if there is any thing you need clarification on i will be happy tho awnser all your questions and edit the thread for accuracy
Automotive exterior Vehicle Luxury vehicle Car Windshield
WoW - Great how too!! I don't plan to take the whole headliner, but I may have to with an upcoming job. This is just what I needed! :)
Reactions: tecollins1
· Contest Manager
Discussion Starter · #10 ·
Thanks for posting this thread. Some of the links don't work on the next to the last post - no pics display and the forum message says something about invalid links.
Thanks for the input!
Ill fix this as soon as I get off work.
Sent from my iPhone using AutoGuide.com App
Wow, great how to!!
My head liner is faulty and is going to be replaced by the dealer! How do you get it out of the car??
Cheers.
My car had the headliner lowered to fix some hail damage. I can hear some rustling sounds above the rear doors over rough roads and I suspect it might be the headliner.
In this picture I see some blocks attached to the headliner in that area.
Are those glued to the steel roof when the car leaves the factory? Do you think it's possible to flex the headliner enough to reglue them without taking the whole thing down? Or can you suggest a fix?
· Resident Derp
They're not glued to the roof, they're just there as spacers.
Thanks for the post, its going to help me a lot this weekend. Im doing suede head liner and wrapping the pillers.
Please... PLEASE use headliner suede, and not regular suede. I used it on mine and we got it to work, but we had to go through 3-4 coats of glue since it took close to an hour just to get it stretched into each crease without any wrinkles. I'm interested to see how it all turns out though, be sure to post the results in appearance/body or the media sub-forum.
· Resident Derp
Will do, im just going to do the headliner in the morning and ill wrap the plastic pillars next weekend.
Yeah my uncle and I used regular suede, and even after trying to pre-stretch it we had to cut part of it and leave a small seam inbetween the rear view mirror and lights.
· Administrator
Can anyone tell me / show me how this clip operates?
Here are a few more pictures from another thread. I asked this before, but I think this thread will be more widely read.
Gun Auto part Trigger
1 - 20 of 25 Posts
