1 - 13 of 13 Posts
That's cool! So there is no issue with just unplugging the panel? No problems with mileage discrepancies or anything like that?
No problem seen during removal and after cleaning. Just got the panel and clean it at home carefully. Thats all and you can see the mileage is still there at last picture. I tested all functions working as usual. But for a safe removal for the panel, I avoid to start car engine without panel. I advice same to you. If not, It is possible to generate some problems without panel if the Ecu is programmed to detect it.
For those of us with an instrument cluster rattle, there is a TSB that says to do this and put a small piece of foam in the channel the clear plastic sits in. Thanks for this write up.
This is perfect my 2014 LT has some strange little lines in the inside of my dash plastic and it looks like some bug/snail was in there and left little trails....i'll take pics later of it but it came like that from the used car dealer i got it from this will finally get rid of those as i can't stand them lol
1 - 13 of 13 Posts
