1 - 20 of 23 Posts
anybody tried removing their manual shift knob? the leather/rubber on mine has torn apart, im tryna get it fix on a upholstery shop IF it is possible to get it removed, geez it sucks livin in a 3rd world country we cant even afford a bnew car.
looking at the 4 speed fan settings, this may be a screw off kind. At least I know the fate of my shift boot as it tore in the 1st 2-3 months.
You can just unscrew the thing. Use a thick cloth like mf towel to protect the surface and give you a decent grip.
all right guyz, as confirmed, shift knob of cruze is removable, but **** chevy dealers in our country doesnt sell shift knobs only, they sell the whole shift box
Knob is removable, just turn clock wise and counter clock wise, some times and knob will be off. You may buy an aftermarket knob los TWM for cars with reserve gear lever, looks mine
If it doesn't unscrew, you can remove the cap and there will be a screw holding it down. Remove the screw/bolt and it will come off.
I took mine off on my eco and there was no screw. It was pressed on, I had already torn it up so I took a dremel to it and cut it off and got one of those universal knobs and that's what's on it now. I'll see if I can find the pieces of the knob, I thought I kept them for reference. If I can find the pieces, I'll post a picture.
That is not correct.
I have a 2013 Cruze. The shift knob is threaded on.
Well I don't know what to believe anymore! I have a 13 and it is press fit. When I worked at Thayer Chevy, all of GM's diagrams had a press fit assembly too. Duvall, did yours have a screw under the cap then?
No, I just gave it a twist and it started turning. It then came off and the shift lever was threaded.
I hope someone else has a '13 with a threaded lever. I am really not special.
I have a 2013 Cruze and just replaced mine.
It was a pain to get off and the new one on.
Remove the outer leather cover and then pretty much just twist and do whatever you can to get it off (it’s not a screw)
Replacement needs to carefully be placed on with a mullet.
2015 Cruze LT 1.4, aka Yuffie, aka RecklessRed
Oh, it comes off. I know it does. Mine is a 2015 LT 1.4t. So, plan on destroying the knob to get it off. It will not be pretty. Get the cap off the top (with the shift pattern) and you will see a screw. If you do, it means that it's press-fit. Take the screw off, grab a bigass pair of vice grips and work it back and forth and it will come off (mabe some sort of pulley puller thing could work too).
Then you will have to find a shift knob that fitswell enough and something to extend down a bit. Nobody makes any adapter for our reverse lockout; what I did after a while of screwing with it, since I wanted a knob (if you have a different style you can tap a hole through the base and the shifter and put a cotter bin through like some other cars have).
For me, I tapped the top of the shifter and essentially helicoiled the shift knob, but a good solid chunk of that weldable, sandable metal patching stuff (like putty. You mix it together to temporarily fix a crack in the block or something), and let it sit overnight, and baby it for the next 24 hours after. Granted, you will have to destroy the knob to get it off again, but it's not going anywhere. I paid like, 40 bucks for the boot, knob, little spacer underneath, and the putty stuff. Aso, I retained my lockout. You just have to grab it over the shift boot, just pinch and pull up, but it's there. Been rocking it like that for about 6 months.
Pardon the mess in the car, but I am in the process of manipulating my sparco quick release and momo steering wheel to work in here. Lol.
285946
285947
1 - 20 of 23 Posts
