Hello everyone. Can anyone tell me how to take off the valve cover of a LE2 1.4L Chevy Cruze engine? And are there any special tools I will require?
It's quite involved, requires special tools to do PROPERLY, and numerous parts to do so.Hello everyone. Can anyone tell me how to take off the valve cover of a LE2 1.4L Chevy Cruze engine? And are there any special tools I will require?
This has been requested by the customs department in my country. I imported the engine which came out of a 2016 chevy Cruze but before customs allows me to have it, the valve cover must be taken off for them to inspect, to be sure no illegal stuff is being imported. So I just need to go with correct tools take it off they take a look and I put it back on then they will release it. So basically it's an engine that is not in a vehicle so I assume it's much simpler.It's quite involved, requires special tools to do PROPERLY, and numerous parts to do so.Hello everyone. Can anyone tell me how to take off the valve cover of a LE2 1.4L Chevy Cruze engine? And are there any special tools I will require?
Why are looking to take it off? I'm happy to help but very curious to know what's really going on before investing more time to make sure you're successful.
You still haven't seen 10mm thread plugs. The LE2 uses 12mm thread plugs with a 14mm hex.I don't think I've ever seen 10mm spark plugs in a car before.
And I've never seen 14mm plugs with 14mm hex.
I'm used to 5/8 or 13/16 hex for 14mm plugs, 18mm for 12mm plugs.
I guess now I know not to be shocked when I see how small the plugs are in a few years.
Highly likely...5/8 is very common. But 18mm plugs are widely used by Honda, on current bikes and all the way back the to the 60s/70s, used by the Cagiva group, Ducati, BMW and most Euro bikes that used related engines, Ferrari has used 18mm in many of it's highest production engine from 80s/90s, Lamborghini, BMW....Etc.My motorcycle was 5/8 I beleive. It wasn't the bigger size.
I'm curious about this fuel rail on my 2016 le2. I put it back on not knowing I'd need to replace the o rings on the injectors. And now I'm getting a low fuel pressure during crank code. When I put the new o rings on is there anything I will need to know. Maybe about applying pressure one way or another. Or just let the bolts do the job?It's quite involved, requires special tools to do PROPERLY, and numerous parts to do so.
