1 - 7 of 7 Posts
I was wondering if someone could explain to me how to remove this front fastener? I’ve tried putting a pick in there to press in, thinking it was some kind of push fastener
That's an aluminum rivet. You need to drill it out. Use a 3/16" or larger bit, you'll only need to drill in about 1/8” or so then the black "head" will pop off, and you can then work the shaft out...you'll push it into the grille
Start with a small bit and step up a size until the head pops..... otherwise you be drilling the car.
1 - 7 of 7 Posts
