Estimated Time 2.4 Hours @ $80 (My shops hour rate) or $192 (WAY MORE AT DEALER!)
Tools Needed for the job at hand. A lot of willpower:$#angry:
Sockets
1/2" 15MM
1/2" 18MM
1/2" 19MM
Wrenches
14MM
18MM
3/8" Drive Ratchet
Hammer
1/2 Impact if You Can:th_coolio:
1/2" 24MM
Small Bottle Jack
Spring Compressor
Floor Jack T40 and T50 1/2" Drive's
2 Jack Stands
Mechanics Gloves
Pick
Torque Wrench
1/2" Drive Ratchet
Step 1:
Raise and Support The Body of Vehicle.
Step 2: Use 1/2" Impact and 1/2" 19MM Socket and Remove Wheel. And Support Lower Control Arm with Small Bottle Jack.
Step 3: Use 1/2" 24MM and 1/2" Ratchet and Remove the Upper Nut and Plate That Attaches the Strut to Body.
Took Picture at My House lol
Here's the Fun Part if Someone That Lowered There Cruze Found an Easier Way Post it Please. No Picture on This Step.
Step 4: Remove the Brake Line That is Attached to the Strut and Then Take the 1/2" T40 Socket and Ratchet and Remove the Sway Bar Link, Then Remove the 2 bolts that attach the spindle/knuckle with the 18MM Socket and wrench. Then Hope you Don't Beat the Crap out of your hands when removing the strut.
Step 5: Install Strut into Spring Compressor.(Professional use should do this step if never used one)
Step 6: Take 1/2" 24MM Socket and Impact and Remove Nut that holds Bearing onto Strut.
Step 7: Remove Upper Strut Mount Bearing and Replace with Brand New GM OEM Part#13505131 Buy 2 ALWAYS! I Went Ahead and Removed my Bump Stops After Seeing Them.
Torque Specs ZOOM in to See.
Then Comes the Other Tricky Part Installing the Strut.First attach the sway bar link kit fully tightened. Then What I did was Held on to where the brake line attaches to the strut and shifted it and turned it until it fell into place then took the hammer and tapped the spindle or knuckle until the two were joined then take the pick and stab into the upper bolt hole. Then install SPC 81250 Alignment Bolt Kit. 14mm wrench and 15mm Socket
Then Just Reinstall Everything you took apart (FOLLOWING TORQUE SPECS.) Someone pointed out that I didn't have adequate torque specs which I thought I did But you cant really see it but when reinstalling you rims use the recommended torque spec of 80 ft lb. Torque specs for the upper nut in the strut is 48ft lbs if you cant read it.
Then Repeat the Directions Above on the opposite side.
Then Have a Professional Alignment Done ( I Have Access to a Hunter ALignment Machine)
Sockets
1/2" 15MM
1/2" 18MM
1/2" 19MM
Wrenches
14MM
18MM
3/8" Drive Ratchet
Hammer
1/2" 24MM
Small Bottle Jack
Spring Compressor
2 Jack Stands
Mechanics Gloves
Pick
Torque Wrench
1/2" Drive Ratchet
Step 1:
