The instrument cluster monitors the odometer mileage to determine when timing belt replacement may be necessary. After the vehicle accumulated approx 100,000 miles (160,00 Kilometers), the instrument cluster may display the "Change Timing Belt" message. After the engine timing belt has been replaced, reset the CHANGE TIMING BELT message by locating and removing the fuse that supply power to the Instrument Cluster for two minutes. Replace fuse and the message should disappear.
