How-To: Top Dash Lid Removal w/Pictures
14569 Views 6 Replies 6 Participants Last post by  Toolbelt
So I have a project I'm working on and needed to remove the dash lid. I figured I would take a stab at it. Turns out it is easier than I thought. I apologize if there is a thread already on this so feel free to remove if this adds no benefit.
Step 1: Open the dash lid (that's a gimme)
Bumper Automotive exterior Vehicle Car Trunk
Step 2: Use a dime or flathead screw driver to pull the rubber piece in the base out a little bit. (Don't worry it isn't glued it is just snug)
Bumper Automotive exterior Hand Auto part Vehicle door
Step 3: Once you pull out the rubber base, there will be 2X bolts holding it in. I believe they are 7mm but mine were apparently loose and was able to just use needle nose pliers and twist them right out.
Vehicle Automotive exterior Bumper Car Hood
Step 4: Once removed, simply pull from the front lip where you open the lid. It will take a small amount of force but then it will pop up. (Don't pull from the sides or back)
Automotive exterior Bumper Helmet Auto part Trunk
Step 5: Keep pulling and remove it out. You will have to slide it a little forward because there are two parts in the back that slide into their respective slots.
Technology Electronics Auto part Electronic device
That's it.. Note: When you put it back in.. you have to slide it forward towards the windshield to get it back in.
1 - 7 of 7 Posts
What are you gonna do in that empty space now??
I put a 7" Magellan GPS in there and love it, it's possible to add a 12V outlet at the middle windshield side to power the GPS or charge a cell phone which is what I did, running the wire is a little tough but doable, I can post a pic if needed
Ahh that's the question.. I am development at the moment so I will update you when I'm done and provisional patented. See what everyone thinks. I have it back in for now as I just needed some measurements and the underlying layout beneath the dash.
I know it's an old thread but curious to how to remove the lid of the compartment
My dash storage will not open. Something is stuck there preventing it. What can I do?
They did away with the dash top storage at some point, replacing it with either a speaker, or blank cover plate.
1 - 7 of 7 Posts
