How-To: Update MyLink radio to the latest version (US) (Nav Units Not Yet Tested)
5852 Views 27 Replies 9 Participants Last post by  MP81
How-To: Update Chevrolet MyLink Radio to the latest version (US)
This thread is for anyone who is looking to update the software for the factory MyLink radio in their Cruze. The update files have been uploaded from my own ACDelco SPS subscription. Please read the post and the instructions carefully, as well as the TSB linked for important information before applying the update. 2013-2016 US Cruzes with this radio should be able to read this update and apply it. As for navigation units, I cannot confirm or test that this update works on one even though the TSB mentions it can be applied. Please check the thread; someone may have posted whether it worked for them or not.
If you are having issues with your MyLink system or want to be up to date you can download and install the update using a USB drive below, currently the latest version is from Sep. 2016. The TSB can be found here, 15-NA-081. It has useful info inside it in case something goes wrong, etc. If you don't have 84009432 Version E0.11.1F.40 in the Software Version Information screen, under Radio Settings, then you should be able to install this update.
Directions to update the system are included with the update, please read them carefully. Have fun updating if it works! If your radio is already up to date you will get a message on the radio asking if you want to apply the update again. Leave a comment if you need help or have a question.
update files (download all as .ZIP in mega)
directions for applying the update
Link to files via Google Drive (mirror in case Mega isn't working)
Tested it on my 2014 Cruze LTZ radio codes UFU&UP9 (mfd.11/13)
Radio software 19Aug2013
Hardware 31Aug2012
also linked is a image of the update verified on my radio
Plant Automotive design Vehicle Gadget Audio equipment
IF YOU HAVE A NON-COLOR RADIO, OR YOUR MYLINK DOES NOT LOOK LIKE THE PICTURE ABOVE, THIS UPDATE WILL NOT WORK ON YOUR RADIO!! I AM NOT RESPONSIBLE FOR BRICKED RADIOS, YOU ARE DOING THIS UPDATE AT YOUR OWN RISK AND KNOWLEDGE!
As of 10/27/22 I no longer own my Cruze and therefore while I'll try my best to answer questions I may not be able to help on certain topics. I also do not have access to a SPS subscription, so I cannot upload any future updates if there are any.
Reactions: Spacepir8
21 - 28 of 28 Posts
Discussion Starter · #23 ·
Well, put the stick in the USB port and the car tells me "No music files found". LOL [emoji868]
On the radio you have to go into the settings/config menu > radio settings > software versions menu > update radio software and it should read your update files.
I believe this is in the instructions, but the radio won’t automatically see it at first until you go to those menus
Now I just get a "Hardware NOT ok" message when Im in the update radio. 🤣
Discussion Starter · #27 ·
Man while I wish I knew what that meant, all I can really say it's probably not compatible. I sold my Cruze last week so I can't pull up SPS and see if there is a separate update. I thought I remember seeing the updates as cross compatible but I don't think I was able to choose a radio unless I'm mistaken. For now I'll assume it doesn't work on nav units unless someone else tries. I'm really sorry about that
· COTM Winner
Those look like "part" numbers (probably of the software update).
21 - 28 of 28 Posts
