How-To: Upgrade to Whiteline Control Arm Bushings
Overview:
Over time, the control arm bushings on your car will get worn and soft. In addition, the OE control arm bushings are soft to begin with for comfort. Soft or worn control arm bushings cause the wheel to gain positive camber in hard cornering, which reduces grip to the front wheels and causes understeer. One excellent way to reduce understeer is to upgrade the control arm bushings with Whiteline control arm bushings. The particular bushings in this tutorial add 0.5 degrees of caster, which increases dynamic camber during sharp cornering and provides more confident and secure handling.
Note: In order to perform this modification, you will need the service of an auto shop twice, to press bushings into and out of the control arm, and also to perform an alignment after the bushings are installed. Be sure to factor that into your budget and car downtime.
Tools Required:
- Wrench with 17mm and 18mm sockets
- Two 18mm wrenches
- Breaker bar just in case
- Long screwdriver or cro-bar
- Flathead screwdriver or fastener removal tool
- Standard claw hammer
Part Required:
Whiteline control arm bushings, front and rear, available on BadNewsRacing.net:
Rear: Whiteline Front Control arm - lower inner rear bushing 2011-2016 Chevrolet Cruze
Front: Whiteline Front Control arm - lower inner front bushing 2011-2016 Chevrolet Cruze
All of the bolts removed are TTY and according to GM, need to be replaced. Use your judgment.
Front control arm bolt x 2: 11589280
Rear control arm bolt x 4: 11589279
Balljoint to knuckle bolt x 2: 11518632
Note: GM says you have to replace the rear bushing bolt as well, but I cannot find it anywhere. In addition, this bolt does not have any critical load placed on it, as all of the load is placed on the bushing itself. I didn't replace this one on my own car but did follow the tightening procedure.
Procedure:
1. Lift both of the front wheels off the ground, and remove the wheels
2. Remove the locking bolt and nut holding the ball joint on
3. Remove the harness fasteners as shown
4. Wedging against the control arm, separate the ball joint from the knuckle
5. Using two 18mm wrenches, loosen and remove the nut and bolt holding the front bushing on
6. Remove the front control arm bolts by using a socket on the bottom and wrench on the top
7. Remove the bolt holding the rear bushing on the control arm. Save all of the hardware removed
8. Repeat for both sides of the car until you have two control arms and two rear bushings
Continued in next post...
Overview:
Tools Required:
- Two 18mm wrenches
Part Required:
Procedure:
