361 - 361 of 361 Posts
I also really didn't want to cut a brand new harness up, so I made a release tool and took the connector apart and attatched the cap to the connectors themselves. View attachment 5957
I like the way you soldered right to the relay terminals. Very slick. I'm questioning the wiring though. The yellow wires are for the low beam feed and the white wire is for the high beam. Same color coding as the oem harness. Shouldn't the capacitor be hooked to yellow and black? Positive and ground. Black being ground. I thought the cap had to be connected in parallel with the relay coil? Or did you use a specialized cap or do something different that you didn't mention? Just curious as how you got that to work.
Rich
