Monsieur Charmant Résident
Should I keep the hubcaps on or take them off?
Or does anyone have any ideas on what I can do for now, since I can't afford rims.
IMO, you should upgrade to a set of 2012-2015 Lordstown-built OEM Cruze LS wheel covers because they look a thousand times better than those fitted to the 2011 models. With a little luck you should be able to pick up a new or like-new set of four inexpensively as take-offs. Check Craigslist and run a WTB ad on CruzeTALK.
FWIW, there's also a chromed aftermarket version of these wheel covers (Hecho in China) if that's your thing, but I suggest avoiding them as they look tawdry, cheap and garish. Good luck: I really do believe you'll be quite chuffed with the look of the updated OEM hubcaps.
click image to enlarge
I prefer the no hub cap look. However the salt from Wisconsin winters will severely rust those stock lug nuts and studs in a short time, those fake plastic lugs on the stock hubcap protect them from this happening. If your dead set on it I would buy new lug nuts that are capped like the chrome ones that come with aluminum wheels(you can buy them in black if you like).
2011 has the special wheel covers .. and they are not hub caps !
2012 , 2013 -and 2014 ...were the dull ones .
If I can get 18 members we all can afford new wheels . MSR 0958-9831 's nice wheels ...
My Girl's 11 LS has the ones you speak of.
