I just bought and installed a set of ICW Banshee wheels. The center hub bore is 73 (which is larger than factory hub bore). I installed the wheels on a rack using spline conical lugs. I do not see any difference in the way the car drives. Should I go back and install hubcentric rings? Is there really any reason to? I saw some information on the rings after I had already installed the wheels. If the mounting holes line up with the studs with no play, I do not see where the ring would make any difference.
