1 - 8 of 8 Posts
I have been slowly hooking up my system using XR's SQ thread as a template. Over the weekend I hooked up the Vifa tweeters and I get the high frequency whine. I searched the forums but most of them seem to be kinda open ended, but the most common suspect seems to be the PAC unit. I am thinking of just biting the bullet and ripping the PAC out to replace it with a better quality line level converter. Before I do that, I wanted to ask if anybody has found the root of the problem being something else.
I used the knukonceptz 4 awg amp wiring kit (with the RCA cables) and I realized that routing the RCA's with the power leads together down the drivers side was probably a bad decision. :(
Is it possible that this is where the noise is coming from? I will probably test it plugging in a different source directly into the MiniDSP to see if the noise goes away, but wondering if anybody has NOT found the PAC at fault with this issue. I would really hate it if I have to reroute the RCA cables.
If your rcas are next to your power thats probably the issue. If that doesnt work check your grounds. But yeah I ran rca next to power on my old truck and it had the high pitched noise. Moved the wiring and it went away. On the cruze I did the amp in the trunk so they are separate, no noise at all.
My amp is in the trunk also. Just to clarify...I ran the 2 RCA pairs from the MiniDSP (which is located in the dash) to the trunk which is routed under the carpet along the drivers side. This is also where the 4 gage power wire is routed.
Are you saying that you routed your RCA's on the opposite side of the vehicle?
That would be advisable .
If youre running rca all the way to your trunk then yeah the further apart the better. I have my line converter in the trunk so there is no way for them to cross. I think if they cross at one point or get close its ok, but running them parallel will cause issues.
Another thing to think about, I dunno how many watts your amp is, but im running 1000 watt amp powering two 12s on 8 gauge I think, 4 gauge is pretty thick unless youre thumping your neighbors to death with a 2500 watt system lol
Is the whine all the time? Does the pitch change with the rpm of the engine?
Yes it changes with the engine RPM. It is definitely alternator noise.
As much as I am dreading it... I think I am going to move the rca cable this weekend.
It's about 500 watts rms and it probably is overkill, but I was unsure what my wants would be in the future.
1 - 8 of 8 Posts
