You should be able to get a replacement from you local GM parts department.The top of the bolts, so I can't screw them in properly. They also are coming loose again. And thank you.
Welcome to the forum.
The bolt threads are stripped?
OR
The bung threads on the Ignition coil are stripped?
They were stripped when I got them from the shop. When I tried unscrewing them, they were extremely tight so it stripped them a little more. Had to hammer a new pattern in to get them out. Any chance you know what size they are?You should be able to get a replacement from you local GM parts department.
Out of curious how did you strip the bolt? Where you using the wrong size hex/torx?
The shop tightened them in too much. They stripped a little more trying to get them out. One of them had to have a new pattern hammered in. Any chance you know the size for it?You should be able to get a replacement from you local GM parts department.
Out of curious how did you strip the bolt? Where you using the wrong size hex/torn? ( I Forget if it's a hex bit or a torx bit?)
Not off the top of my head. You should be able to get a replacement from GM though.They were stripped when I got them from the shop. When I tried unscrewing them, they were extremely tight so it stripped them a little more. Had to hammer a new pattern in to get them out. Any chance you know what size they are?
Thank you. And apologies for the double reply. My phone was acting up and didn't show that the reply went through.Not off the top of my head. You should be able to get a replacement from GM though.
I tried that before. The home depot I went to was no help. Though I can try again. Thanks!I would suggest that you remove a bolt and take it to ACE or Home Depot or any other place that stocks bolts. They can help size it.
Welcome to the forum!
