1 - 3 of 3 Posts
Question one of my bolts for the ignition coils is missing and its on back order right now can i use any bolt from like home depot that is matched or does it have to be from GM because no one has them.
I might try a junk yard first. The drawbacks to hardware store bolts will be getting the right size - in particular, the right length. The other issue is getting the right plating - hardware store bolts may start rusting.
You might check at the auto parts store. They may have bolts with better plating. Take your one good bolt to check size and thread.
Doug
2013 Cruze LT
I 2nd that, I know autozone has a section where you screw your existing bolt in and it tells you what size and thread it is. Do that and get a stainless or zinc plated and I cant see if being an issue.
1 - 3 of 3 Posts
